A Winner has been selected for the 2025 Radioddity Cyber Monday giveaway! Click Here to see who won!
Pretty sure the question pools have changed since then. Best way I know to succeed is to use the free online sample tests. By the time you can pass those tests more than half the time, you're probably ready. Since the correct answer gets revealed for the questions you miss, you will eventually see the correct answer to every question in the pool. If you take enough of them, anyway.
The question pool for the Technician exam changed this past June. Like Nomad said, there are plenty of online learning/practice sites that make the process fairly easy to get through.
