Wondering if anyone has any insight. Purchased a clean sb200, RTO electronics went through the amplifier in 2012, replaced relay for newer transceivers. My issue is I cannot get more than 250w output. HV idle voltage is 2400, keydown 2100 volts. 10w drive give 200w out, 20w in and barely 250w, 40w in 250w. If I tune the amp at higher drive and back down the drive, seems like the ALC is cutting out all wattage as it will cut voltage down. Not sure what to look for or test.
Thanks
Thanks
