help,hustler mx 270
Rwb
tell the devil im gettin there as fast as i can,r
Jun 30, 2018
4,367
6,447
523
71
ive had it on roof of my pickup 4 years always had great swr on 2 meters as well as 70 cm. was driving and a bit of wind blowing.a limb came down and hit the mx 270. radio was on was listening to talk.it grew silent. stopped and it poped the mag mout over. put back in place still quiet. got home tried swr meter WOAH high every where. removed it and discovered the whack broke the ceramic disc in coil. i ordered a few from elliot electric. took new 1 trimmed legs same as old 1,soldered it in same exact place on coil. put back on mount . swr nice on 70 meters but 2:5 to 1 on 2 meters.
what now? do i loosen set screw at bottom move antenna up or down or what? will moving bottom part screw up 70 cm?
the antenna is on top dead center too.
dont bring up the bore a hole in roof crap too. no for reasons .
for time being i put a tram i got for a temporary base mount on magnet as its same mount as mx 270. it never was as efficent as the mx 270.
Maybe mark the whip with a Sharpie where it was good on 70cm, then try to tune for 2m. Hopefully there's a happy spot somewhere for both.
Have you thought about drilling a hole?? (joking Robert. Just joking)
Good luck with it,
7 3
Reactions: Rwb
Good luck with it,
7 3
was thinkin mark n move. this was best antenna i ever had. tx and rx was better than a friends 1480 tram base. i was at his house. we were thinking test time. repeater was on frine edge for him but my kenwood g 707 n mx 270 locked it in n i talked to a guy
Reactions: Crawdad
Good luck with it,
7 3
im going to get a friend to get his anylizer on it. i got 2 meters low n 70 cm went up. right now i quit when 2 meters was in a 1:4 to 1 and 70 cm was 1:8 to 1. plus we want to check new signal stick to original on my new uv 32 baofeng. im liking that radio more n more too
Reactions: Crawdad
