I pulled this kit out of a non working radio today. No luck on identifying what kind of kit it is or the hookup procedure to see if it still works. Here are a couple pics showing all distinguishing marks:
Top side of the two pieces. Smaller one gets soldered directly into the spot where the ribbon cable from normal channel selector would go. 3 wire connector connects it to the bigger board which had a red and black wire heading to the board...im assuming power and ground...and then two wires heading to the clarifier.
http://prntscr.com/4lo8rc
http://prntscr.com/4loa5w
Any help identifying these would be greatly appreciated
