So I was reading that this may have been marketed as a 120 channel radio, but that it was largely marketing hype. So far I haven't found any manuals or anything that clearly describes how I should operate it. I would like to put some voltage to it this evening, but the 120 channels is not something I'm familiar with. For basic AM, which should I use Lo Med or Hi? Is Lo for LSB and Hi for USB and Med for general AM usage? For modern usage, does one even need to swap back and forth between them or will the clarifier pretty much do the job in SSB?
A little confused,,,, thanks in advance
