It's amazing that none of the 200 people who looked could tell you that everything you need to know about the Gen 702A is in Sam's # 233. If you don't have access to the sam's, adjust L203, 204, 205, 206, 207, 208, 209, 210, and 211 for maximum rf output while modulating the unit with a 1000 cycle tone. Use a PLASTIC tuning tool. Replace C1 (2200uf/35V) on the power supply board with a 4700uf/35V electrolytic. Connect a voltmeter to the red lead on the power supply board and ground, and adjust VR1 until you get a reading of 14.8vdc (it won't do much more than that). Modulation adjust is VR206 or cut D209. A decent power mike would really help this radio. If you want the receive aligned, I suggest you take it to a good tech who has the proper equipment. For extra freqs, connect pin 14 on the pll chip to ground thru a switch. 73s.
- 399
