Hello all, I'm new here and this is my first post. I've recently got into CB radios and acquired a few older CB Radios. I love fixing things and I'm enjoying the challenge of potentially fixing this radio. I took it to a reputable repair shop and he said it wasn't worth fixing, but I suspect he didn't even open it up.
The one I'm trying to troubleshoot is a President Grant. The board says PC409AB on it. The problem is it does not transmit, or receive, the PA function doesn't work, and when you first turn it on, within 5 seconds, the channel display fades to nothing and usually won't come back until the next day, at which point it will fade to nothing again. I did get the channel display to stay on for a while once, but it was weak on the dim setting so had to keep it on bright, but that didn't last long and reverted back to fading to nothing.
So far I have cleaned all of the knobs/pots with deoxit, removed and tested the C95 cap, noticed that the TR24 transistor has been removed, and removed and tested the C84 cap, because it looked like it had leaked a brown substance, which I now believe to be glue. I also purchased a new mic from Amazon, this radio has a 5 pin Mic. The radio has 3 switches that were added to the bottom, but I have cut the wires to all of them so I could get the bottom cover off...the wires had no slack.
What should I check next? Thank you in advance.
