Help with Bajoie BJ-300 Chinese amplifier
Negative feedback is all about reducing gain. Maybe that will tame a transistor that has ten times too much gain? Never had to try.
R10/R11 and R13/R12 provide negative feedback.
It appears to be set for unity voltage gain (1k for both resistors).
I imagine the input transformer supplies needed voltage gain, and the push-pull output only supplies current gain.
Regarding having the "wrong frequency" for the transistors, all transistors have a gaussian fall-off, with "ft" defined as the unity-gain frequency. I do not understand how having too high an ft would make them inappropriate for HF, especially since the voltage gain is set by negative feedback.
Personally, as an RF engineer, I don't really have a problem with the schematic or the components.
Reactions: Naysayer
Not so much inapropriate as unstable. An amplifier circuit appropriate for a 30 MHz transistor may present an oscillator circuit for a part meant to run at a frequency ten or twenty times higher.
That's what bypass caps are for. I see several of them in the circuit. They need to be physically close to the high ft transistor.
I'd rather have too much ft than too little!
Reactions: Naysayer
As an RF Engineer, I've done dozens of such designs.
This one might work a bit better with high ft transistors with some PCB layout tweaks, but I see nothing obviously wrong with it.
Rule of thumb here, is fT x 2 of design frequency.
The amp is $100. Buy one and make it work, then share your mods and results.
SL
But with the given feedback resistors, it's running at unity gain.
By your logic, just about any op-amp design should be an oscillator.
  • @ 357:
    holy man no activity or what?
    357 has left the room.
  • @ Hambones amps:
