HELP!!!!!!!!!
CDX197
528
Nebraska's cornfields
K i got the whip hooked up to the truck. I have it on a piece of metal that is bent down to the box. I have a wire that is connected to the metal that the antenna is hooked on to down to the frame. I have everything very tight so it makes a ground. But i still cant get out. I have tried everyting. New mics, New coax. The box is bolted strait to the fraim. Will i need ground straps? I can hear for about 5 miles but i cant get out 100 feet. :( Can anyone help me out???? Thanks CDX197
Wont belive this but it was Dead Flat. I tested it out on my Radio shack meter on 20 watts. Set it on SWR and PEP and the meter didnt move a bit. I was told that i was keying up but no one could here me. I tried another mic and it still didnt work :( Im lost!!!
mic
CDX197 said:
well guys i figured out that all i needed was another mic. So its fixed now, Just one simple thing is all it was! :roll:
Dont you hate when that happens :oops:
Ive had worse. One time i had the mic gain turned all the way down. Couldnt figure out why it wasnt working. Then remembered i turned a wrong knob earlier in the day and there was the problem. :oops:
