Sounds like a plan.
Just take a wild guess at how tall the coil was.
Sounds like a plan.
That's not a ground plane. Notice the "hot"side of the antenna is connected to it making more like a bottom mounted capacity hat. A cap hat needs to be on top of the antenna, hence the name cap hat.
That's a shunt coil connected between hot side of antenna to ground used for matching the impedance at the antennas feedpoint. A non coiled mobile antenna like a 102" whip may benefit from this for better matching.![]()
here ya go
In the states we call it No Ground Plane antennas. Or NGP
I know I will get jumped on but Firestick has them.
http://www.firestik.com/
A NGP just uses a special coax as the ground plane. Ya it gets the radio happy and it's better then nothing but the performance will never match a proper antenna system. With NGP you have to use their whole kit.. mount , special coax, special antenna. You can't just slap a whip on your existing mount and coax and call it good.
Do you have any links to specifics? I have a "fiberglass body" and trying to distill some things. Primarily, if the frame of my car is aluminum and other metals, does this give me any hope compared to the steel in a vehicle's body?A few wires or aluminium foil work great as counterpoise in fibre glass cars.
Mike
And, as an exercise, how much steel do I need? If I just replaced the hood or fenders with steel ones - for instance - what is "enough"? Or is it never enough?
When I vice grip my 102" to a shipping container, for instance, if that container was covered in fiberglass, how would that change the dynamics? I.E. would the steel underneath be "enough" or does it have to be the "outside" of the said antenna mount?
I've been there! And it is good stuff - I've been wanting to put a mobile rig in my Corvette (10/11m) but the complexity of trying to understand a way to make it work has kept me from doing anything serious.Ratt,
A great source of info on mobile installs is the website of a well known amateur K0BG.
www.k0bg.com
Anybody notice how this coax could be different?
