Home Stereo Question
Wire Weasel
Senior Moment
Dec 13, 2008
3,308
970
223
I have a typical old school home stereo with an integrated components amp, separate CD player & equalizer plugged in. Have two large A channel speakers and two smaller ones for the B side.
Can I add a subwoofer to this stereo? If so, would it be a self-powered type or something and what would it connect to on the stereo? There are no outputs set aside for a subwoofer.
Thanks for any help!
you would need a passive subwoofer. one that is powered by the speaker leads themselves.
i use one in my work van ...an old radio shack down firing 10 or 12 .
it has a crossover network inside that directs to lows to the sub and the mid and highs are sent back out to your speakers .
you hook your speaker leads to the sub on the input side ,then you use the sub outputs to run to your front speakers .
you could also get a powered sub that does the same ,just be sure it has speaker level inputs and outputs.
Actually, you will need a passive crossover tuned for 150hz and below. Feed the amplifier output to this crossover. The output will split up in two directions: one will got to one of your regular speaker, and the other to the sub. A 12db Butterworth-type x-over is sufficient.
