Homebrew 4 hc 2sc2879
Kd4tmb
Jan 26, 2019
3
67
Built a class c amp running 4 2sc2879 Hg transistors, similar to a fatboy amp. Any suggestions on best way to change bias to AB for ssb? What about circuit improvements for durability?
I'll use it on a regulated astron 70amp power supply.
Thanks
Bias circuits for that type transistor are all over the map. Seems like everybody has their own secret sauce. Something we have found in the past is that an amplifier layout that isn't completely stable will still behave fine in Class C, or seem to. In one case it took between a quarter and a half Watt to make the transistors turn on and amplify at all. The transistors completely ignored any input below that level.
But when bias was added, the amplifier wanted to feed back and oscillate. Adding bias had made it sensitive to input levels of a tenth of a Watt and far less. That amplifier's layout caused it to have roughly the equivalent of 1/20th of a Watt of feedback going on. So long as the radio's input was greater than that, it would swamp out the feedback as if it were not there at all. But adding bias would cause the amplifier to stay keyed after the radio returned to receive mode.
Oops.
Adding bead chokes, more negative feedback and tweaking some capacitor values calmed it down.
Could be that adding bias will go smoothly without drama.
Haven't done it in a while. I'll see if any archival docs survive and post them.
Amp works well on FM, Might be best to leave it as is. Had parts laying around and decided to build something simple before my eyes and arthritis got worse.
If you come up with something that might work let me know, I appreciate your help.
