rfparts.com sells carbon comp resistors in 2 watt values up to 1M ohm. You guys can correct me if I'm wrong, but if you use resistors that are, for example, 2W 300ohm, you would use 6 resistors in parallel for a dummyload of 12W and 50ohm. (2W x 6 = 12W) and (300ohm / 6 = 50ohm)
