How to broadband a 5/8 wave
My two most recent, and best antennas I've had in recent memory are the sirio 2016 and sirio gainmaster 5/8.
The 2016 is a fairly broadband antenna. But the gainmaster is awesome! I know in the past it's been susceptible to high winds and they have worked on that. Mine has taken some serious wind, no problem.
When they say No tuning required, that's what you get.
Nothing you can do. If you need more BW, buy a different antenna. You could try soldering a 50 ohm resistor across the feedpoint. That should give you all of the BW you could ever want.
What would that do? I know it’ll shunt it and make it a dc ground basically. But beyond that?
It is a radiating dummy load, almost infinite BW. Probably more efficient than the incandescent light bulbs, people used back in the day, and poses a true 50 Ohm resistive load.
Reactions: nfsus
  • @ Spanish:
    Where do i upload schematics
  • @ ShadowDelaware:
    Who do I contact for a name change. I put in for it over a year ago and it says still under review.
