HR 2510 AM modulation
radiomaniacc
Jan 30, 2010
25
2
13
Hello,
I'm noticing that the modulation of my radio sounds a little muffled. It is not as sharp and clear as it should be. The AMC is adjusted to the correct level. Even if AMC fully opened the mod sounds like that, so is not that. The radio is setup 4 watts carrier and aprox 12 modulated. Changed the stock mic for a power mic for testing, the same thing. Even on ssb it sounds like that. What would be causing this ? Is any other setting on the radio to correct this ??
Thanks !!
radiomaniacc
It cuts all high tones at mic preamplifier stage.
Depends on your microphone after removing this cap you might have to much highs on your audio and it will sound hissy. Value that I used in mine radio is 68pF, in radio a friend od mine 100pF was right value. In some radios just removing it was enough.
So first of it all remove it and listen yourself on second radio.
Mike
And to make 2510's loud....because they were also known for low modulation/stock, remove the modulation limiter and add a power mic. I used a Turner +3 on one for years, sounded great.
  • @ Hambones amps:
