i really need your help!
Porkchop
May 27, 2005
40
U.K.
ok guys,i really need the wiring diagram for a magnum omegaforce to turner +3b mic.
i've searched the net,but cannot seem to find what i'm looking for.
i know there's someone out there that can help
cheers! :?
here is the mic wiring link
mic wiring
and radio wiring is
Pin #1 ~ Microphone Audio / White
Pin #2 ~ Receive / Black
Pin #3 ~ Transmit / Red
Pin #4 ~ Down(Up w/22K Ohm Resistor) / Blue
Pin #5 ~ Ground / Shield w/yellow sleeve
Pin #6 ~ +13.8VDC / Brown
cheers for that..nice one :D
are you sure this is correct though?
from what i can gather it should be...
Pin #3 ~ Transmit / Blue
Pin #4 ~ N/C
Pin #5 ~ Ground / Shield w/Red
Pin #6 ~ +13.8VDC / No Wire
am i getting this wrong? because when i insert the plug,the radio goes quiet,and the tx sign comes on,but with no modulation!
i'm beginning to think that this combination is not going to work
  • @ AWP:
  • @ wavrider:
    sea que sea que,
