Icom 706mk2g
Follow the steps that dragracer provided and you should be able to toggle between fast/slow AGC by pressing the F-3 button. ;)
• “FAGC” appears when the fast time constant is selected
ALWAYS appears .... if you want i can make a video short one showing that it only says fAGC no matter if its in 440/2m/ or HF bands.
I just checked mine. It will do what you are saying when it is in "FM" mode...when it is in any other mode it will work as I posted earlier....
In your video I can see in the display that it is changing. It says "FAGC" when you have it in fast agc. Then when you change it the "fagc" shuts off in the display. I just checked mine again and it does the same as yours. I dont think you will notice anything until you have a strong signal coming in. Then you can see a difference.
thanks. yea im not stressing on it i only use agc when on ssb with a station far away. helps clean it up a tad...:pop:
