Retevis is giving away THREE radios for their 16th Anniversary! Click Here to enter!
My 720 has very low output on ssb and the mic gain is very low. The only way to get it to work is to run it turned way up and rub the compression turned on and my turner sskturned up. What gives?
Exactly, the 720 has a mic amp built in and requires a special mic element. The 104, 1104c, or turners just don't sound good. For mine I always use the ICOM SM6
Well the issue is not a mic gain problem, it is a problem in the compressor circuit. Is there a vr pot I can adjust for the compression? It seems like that has been turned way down.
