ICOM IC-7000 external cooling-fan
AudioShockwav
Extraterrestrial
Staff member
Apr 6, 2005
9,954
11,045
718
Sierra Nevada by Yosemite National Park
From VK5CQ:
ICOM IC-7000 gets way too hot - even in standby/receive modes -for me to feel comfortable running it, particularly in Summer or a closed vehicle.
Its internal fan seems to run only in transmit mode, leaving the case to feel too hot to my hand, in other modes.
A simple workaround requires:
plug for radio's [little-used] external tuner jack;
a short length of wire (2 leads, ideally red & black);
a small, quiet but effective, 12 v dc fan, whose current drain is below the limit of that provided by the radio, via its external tuner jack.
Assemble the above parts into a removable module, and - when you would like to use it - safely mount the fan on or near the radio & plug it in.
Fan will cool radio whenever the radio is On [potentially extending the life of the radio].
(Giving credit where due: The idea for this mod comes from W2ENY's eBay item-description for a fan + cable-assembly that does the external cooling for various ICOM transceivers).
