I'm in need of a schematic for a Cobra 19+ with a C5121 PLL
L Bjerke
Jan 19, 2020
9
3
13
71
Does anyone have any idea where to get a schematic or service manual for a Cobra 19 plus, from what I've read its the late model as it has the C5121 PLL IC...I have 2 radios like this I found at a rummage sale for a little of nothing but neither will transmit or receive as the 10.24 Mhz osc is dead.
Thanks
Need more info, Pic of the board?
Some used a uPD too - very early PLUS (Note CAPITALS) units used a microcontroller (back then about like the 6502) to program pins for the PLL and handle Display functions.
You'd have 2 chips - else 7132 might be more close...
either way - we're guessing...
Reactions: L Bjerke
5121 is CMOS chip, be careful, it is very easy to kill by static or not grounded soldering iron.
See schematic attached. Different radios, but c5121 application visible.
Mike
Reactions: L Bjerke
I’d look at removing all the corrosive glue used on those sets. Both versions of the 19+ radios are notorious for the damage caused by it, especially in the PLL area. The crystal is usually glued to the top of the PLL chip as well as glue spread all over the print side under the chip. Another common problem involves the small circuit board attached to the two switches on the front. Pressure applied to those switches over time causes the solder connections to break loose away from the main board. If you decide they’re beyond reasonable repair, among other parts, save the LED display. The LED is compatible with common anode 16 pin displays found in the Cobra 29 and others.
Mike
Mike
Mike
Thanks for the schematic Mike, that will help a lot.
I have another 19+ that works OK but the radio looks like it was run over by a truck, I took the PLL IC, 10.24 mhz crystal, and variable cap out of that radio and put it in the non working one but it still acts the same also I injected a 10.24 mhz signal into the DO pin of the PLL and I did get noise on the speaker with an antenna hooked up however when I transmitted a working radio on the same channel I couldn't hear my voice so I assume my non working radio is on the wrong frequency, and the transmit still doesn't work.
I also cleaned all the glue off both sides of the circuit board when I had the IC out.
Well, if you get a display - like the channel and the buttons work - like up and down - then the 10.240 is working. It's needs that to even "Calculate" - that's it's - "clock"
I'd look further into the "Exciter" portion of the radio - that is in the tin box on board.
It also pays to unsolder any of those tin foil shield plates underneath too. You may need to look under the foil to gain access to the PCB board under it and check for cold solder joints and any debris that may have sandwiched itself there. The "Exciter" I'm talking about, is that radios VCO section.
You may get it working again if you reflow solder. If you have the board I think you do, then you've got a side edge card riser for the channel display meter and up/down buttons - if those crack open or the radios been dropped - these break and if that occurred, you're gonna be hard pressed to try and reflow solder on torn-off foil pads.
If the channel display works, you may be in a better position than you think. It just may be from age and a fresh Electrolytic cap or two, along with a tweak of the exciter, just to get it working again...
Look over the attachments - see if it's the radio you are working on...
Note the bottom - Foilside - the edge connector pads can be seen in the photo just to the front panel side of that insulator.
Thanks for all the information Andy!!..this is the radio I have, looks exactly like the one you posted pictures of. I can change channels up and down and the display works fine, I checked the 10,24 with my scope and don't see a signal there but it must be there because the display works, I'll remove the cover around the VCO area and look for bad solder joints. I don't see any obvious bad caps but will look around that area and possibly pull them and test them...thanks for the information, its greatly appreciated
When you say you "check" - how or what are you using to do this? There's not a lot of places labeled TEST POINT on that board...
Did you see this?
See Below...
The Xtal itself may work - but remember the Exciter is also trying to do something too. It's attempting to "ring" and start the loop feedback process.
To start, look at the Blue Box section, the Xtal and there are two small caps, one is a trimmer cap to the right of the Xtal on the board (below green braid) and to the left of the Xtal is a square cap - these "trim" that crystal to a frequency close to 10.240 - but not exact - the CX trims to further fine tune it.
The Yellow Box shows two TANTALUM caps the PLL uses in a loop to two speeds - one high, the other low, they clock thru the PLL and as they "sync" together - this signal is a lot like a frequency. The PLL then determines this exciter and the divider inside itself if the channels are able to be tuned to - it uses the Exciter as the other half to check for "sync" and sends a error correction signal as part of this "Check gating for sync" process.
This is what made this radio unique, most of the other 5121 or 7132's used single cap designs for signal - ok I guess but was not the best smooth waveform the radio can use for IF processing - which the line sampled from that output of the Exciter - so if it was noisy - so went the IF...
Now, how do I know about that clock - is because if it doesn't lock in or find any frequency on any pin, it'll just keep the display blank - it's for the reason of servicing - to show something has failed internally.
Did you check the Exciter coil - any "tampering" of the wax?
This thing is old, but there are spots on this board, that use older electrolytic caps that can dry out. That also can affect the signal you're trying to find. IF the coil is ok, but the parts have drifted off. That wax section will need some of the work you may have to "replace parts" done to it. That means removing as much wax physically before you start to reheat and remove/unsolder parts. The wax needs to be warmed, slightly, and removed so you can get at the parts, just don't apply too much heat at first so you can soften it then remove as much as you can in one piece.
So look into what I've listed above in a previous post - clean it up and reheat soldering joints in and around the VCO/Exciter section to see if you can get it to start oscillating (Ring). The Xtal itself may just need to be cleaned up or get the "glue" bonding it to the board/chip removed - so it can send more signal you can detect.
Something tells me that the Xtal may not be the problem but the caps used to "trim" and the dirt that the thing can collect around the glue can start siphoning off signal. See the schematic reference graphic above on the right.
Considering the size of these things, they can be put just about anywhere in a small car onto a Chrysler Mini-van and were used like CB's onto even French Fry and Cup Holders.
So some can be abused and may not even work - it's the law of diminishing returns - you can only go so far before you have to give up on the cost or the effort or both.
I removed the plate on the solder side of the board under the exciter and powered it back up, with it removed and it worked, flipped it over to the component side and it quit again so I re-soldered all of that area and now it works BUT it appears someone has been inside there messing with things as I get 7 watts of power according to my power meter, I powered up a working radio and talked into on channel 15 and I can hear the radio I'm working on on channel 14, 15, and 16, it even bleeds some to 13 and 17 so I'm guessing it needs an alignment and that may be an issue as I don't really have the equipment to do that, I have an oscilloscope, frequency meter, and signal generator however I'm used to working on AM radios and it only goes to 20 Mhz not to the 27 Mhz I need for CB radio repair, I enjoy working on CB's so might as well invest in a decent signal generator that will go to at least 50 Mhz, any ideas on what to buy, would rather stay around $150 or $200 tops if that's possible, I know there are some Chinese ones out there for under $100 but what I've read on them isn't good, BTW thanks for all the help
Reactions: Woody-202
Right now, I'm not in the market - so I'm the wrong guy to ask - all I got is an older 60MHz scope - bought used.
It works, but you do mot need "fancy equipment" - don't succumb to that pressure. This is CB, it's AM and about as simple as it gets.
You just need to remember a few tricks to help you...
Remember where you started, because at Square one, is where you and it, got it all together and started...
Work in small increments. Rome was not built in a day. So don't rush - you can make some serious mistakes.
Log your work. Document! I mean; take notes or run a camera to show you in action on that radio - so you can play it back and find where you need to go back to and do over if needed.
So it is not a lost case, just make sure you have the right microphone for it.
These things used a 5Pin DIN Radio Shack style mic plug and jack for this radio - but it used power from the radio itself to power the Electret condenser element in the handset.- so Grey Key mike for the radio and only this kind of radio. It's how this radio works.
I gotta' do some stuff for the wife, but will continue shortly...
Reactions: L Bjerke
I received mics with the radios when I bought them and from what I can tell they seem to work ok...I got the 2nd one on the bench this afternoon and found exactly the same thing with it, bad solder joints but a lot more than the 1st radio had however this one seems to work a better as it doesn't over drive the channels on the side of the one transmitting on. I had it where I thought it was fixed then it started scanning channels on its own after it was on for awhile but that turned out to be an easy fix, the capacitor that is off pin 20 on the PLL was leaky, a new one fixed that, I also pulled half dozen electrolytic caps out and tested them and every one was way out of tolerance so think I'll replace them as well as long as I'm in there playing around, I buy caps by the hundreds, mainly stick with Nichicon as I can buy them quite cheap in quantity and have found the quality of them to be really good for the money. I do some higher end vintage stereo repair (Marantz, Kenwood, Sanaui, Poineer ect) so most parts I should have on hand that I find bad in the CB radios other than IC's as they use a lot of the same components. but CB radios are something new to me. Once again thanks for your help, I still have one more to look at, I bought 4 total for $15 but one was beyond repair as it looked like the front of it had been run over by a car or something but I bought a Marantz 2270 receiver on eBay not working that I'm going to tackle next...Have a good evening and I'll talk to you later.
One other thing I meant to ask, I adjusted the voltage of the VCO like it showed in the one message you sent, it started out at just over 2 volts but it came down to 1.5 adjusting L6, question is that was on channel 1. it changes with every channel, from what I read online that's normal...correct?
Correct...
Longer version...
That is how these things work. The PLL will send a signal to a pin, raising or lowering a voltage.
The voltage goes to a Varactor - a type of diode that has a special doping...It is designed to work like a diode but it's got a really thick substrate - read wafer, read chip, read doping material and SEE SANDWICH...
You can read more about this device at this link
Only this one, when you put it in a circuit the right way, changes capacitance based upon a voltage.
So L6, That Diode - and the voltage from the PLL - along with a 10.240 Xtal - is really all that you need to focus on.
The PLL GENERATES a signal for the EXCITER using the 10.240MHz signal as a REFERENCE.
  • The Radio USES The EXCITER to power one part of the Receivers three stages to receive AM signals
  • The Radio USES the 10.240MHz Xtal to Power another part of the Receiver's three stages to receive AM Signals.
  • The Radio USES BOTH EXCITER and 10.240MHz Xtal IN a method of SUBTRACTION to generate a 3rd signal used in the 3rd stage to Receive AM Signals.
  • The Radio USES BOTH SIGNALS to Power TX - COMBINED together to make 27MHz.
  • The Radio USES a process know as Heterodyne to obtain signals for further processing in High-Gain amplifier stages.
  • Heterodyne can be used to COMBINE as well as SUBTRACT two frequencies to generate another.
You can read more about this process at this link
Once you understand the process of MIXING and deriving two other signals - One ABOVE the two frequencies (Summed together) and another BELOW the two frequencies (Subtracted from each other = Difference) you can then apply this to your situation of arriving to the correct frequency and letting the PLL do the correction work for you.
The Exciter - that L6 coil - is a free running oscillator that uses that tiny voltage change from the PLL to adjust its' free-running frequency - it's checked by the PLL using a "gating process".
  • The PLL "Checks itself" using a ROM program to set a counter and the frequency it looks at from the Exciter then is used as the actual "count" as a process of dividing down and seeing the that result is good - hence the Gate - Open or Closed - and corrects accordingly depending on the state of two gates it checks this result with. An Error signal is sent to the exciter as a correction - a looping feedback process.
Will add more as time permits - you have a lot to read here - just enjoy the post as fun for a change...
Reactions: L Bjerke
