im lost!
Se7en
Jun 27, 2010
4,573
223
Ca
I'm stuck at the Beef Terminal and i cant find my way back to the text under my User Name!
You are on the Third rock from the sun..
The Star is 7/8's the way out on one of the spirals ( the Orion arm about 26,000 light yrs from the center of the milkyay galaxy) in the spiral Galaxy known as the MilkyWay Galaxy
( No Not named after the candy bar )
Just round the corner from the Andromeda Galaxy ( another spiral galaxy a bit larger then the milkyway galxy )
look for the dwarf galaxy sagittarios on the outskirts of the galaxy currently being devoured by the milkyway.
Kindly refer to this link if you are still un sure where you are ( http://www.atlasoftheuniverse.com/milkyway.html )
Kindly refer to this link if you are still un sure where you are ( A Map of the Milky Way )
I remember an old graphic that probably came from the days of the early astronomers.
Our sun was named Sol, hence Solar System.
The Earth was Terra, hence we are Terrestrials.
Funny, I once gave my address as living in the Solar System, Arm of Orion, Milky Way Galaxy.
May The Force be with you always...:D
Reactions: 2 people
When you get stuck at the BT, This is what you see and hear....
MegaRay X2 - YouTube
