So whichever way I go, do I put a screw in each side of the dipole and run the hot side of the coax to one side and the ground of the coax to the otherside?
Pretty sweet. What kind of results are you seeing with this.
I was looking at Walmart.com and all I found was a pole that was 6'6" long, but it does look just like the one you are using.
Any dipole antenna can have a 'broadly' directional radiation pattern. 'How' directional it get's depends on it's height above ground. That radiation pattern starts of not directional at all, omnidirectional, begins to get sort of oblong'ish, and then more directional in broadside directions at greater height. So what's the height where it get's 'directional'? Typically around a full wave length and higher it's as directional as it's going to get. It's never going to be as directional as a beam of any kind and will be bi-directional in broadside directional.
Think of it as two flood lights back to back, sort of. Ain't never going to be two spot lights.
There's a roughly minimum height for that 'best' directionality, something like a full wave length above ground, there's no maximum height for that directionality.
That help any?
11 meters = 36 feetAny dipole antenna can have a 'broadly' directional radiation pattern. 'How' directional it get's depends on it's height above ground. That radiation pattern starts of not directional at all, omnidirectional, begins to get sort of oblong'ish, and then more directional in broadside directions at greater height. So what's the height where it get's 'directional'? Typically around a full wave length and higher it's as directional as it's going to get. It's never going to be as directional as a beam of any kind and will be bi-directional in broadside directional.
That help any?
I used two old mismatched firestiks and a piece of flat stainless stock to make one this afternoon. I drilled two 3/8" holes for the antennas and two 1/4" holes for some woodscrews. The 7' was standing up with the coax attached and the 5' was looking down and just bolted to the stainless. I screwed this to the underside of the eave on my house and hooked it up to an old 949. SWR across 11m is below 1.5:1, could use some tuning but I'm just experimenting. After this nation wide squall line blew through, skip was gone but some of the locals were coming in good. My roof blocked most of the signal, but it did work.
That's a lot of mounts. Lowes carries fine thread nuts and bolts that'll fit antennas. You could also pick up some flat stock, angle iron, and some small nuts/bolts there and fab that same thing for probably the same price.
I'm contemplating trying one out in a tree top made with a couple of old whips that are laying around.
