Imax above a 10 meter beam?
airplane1
Apr 15, 2005
1,051
32
58
Lebanon county PA
I know people do the Imax above beams all the time and from what I gather it helps the Imax by acting as a ground plane for it.
This is fine but I seen one person on the internet say that if I use the beam under the Imax as a ground plane it will detune the Imax so as it will not work on 17-15-12 meter any more.
I want to use it on these bands not just 10 meter.
Any one have experience with this setup?
Thanks,
AP
I cant imagine it would cause that much havoc I see people do this all the time I have talk to several that explained there setup as either an antron or Imax above there beam. I cant see how this would cause any issue at all aslong as your obviously running the beam horizontaly or flat.
I don't think I'd worry about the potential problems that much. It might cause some pattern distortion on the vertical, but I doubt it would be enough to notice.
