inside a wilson 5000 coil part 1
fnkycoldmedina
Well-Known Member
May 18, 2005
2,266
98
58
pa
this coil started giving up and down swr readings .i switched it out and broke out the dremel on the old one .
heres what they look like with a side cutaway.
By null at 2008-02-09
notice the large silverplated coil
this area was not the problem.
heres a shot with the covering removed.
see that gooey stuff?
its gooey.........its silicone like.
on to the problem........
heres part of the problem.....water has gotten in.
Shot at 2008-02-09
this can happen.if you suspect it has....remove the chrome tower where the whip insets(it screws off)let air dry a good 24 hours ...then add silicone or some other sealing agent and reassemble.
we are getting to the problem.
heres a couple random shots of the open coil.....
the problem area is in view
ok .....heres the problem.
see this nut.
it was loose.causing the stem to rock back n forth making the swr jump around.make n break the connection so to speak.
had this mag mount been designed in a way as to access the insides without trashing it this could have been cleaned ,tightened and put back in service .
look at the corrosion ,this nut was loose
what you are going to see now is where the coax feed is soldered to the coil,
you could actually unsolder this and by moving it around on the coil you could tune this antenna by hand for different bands ,or make up for too short or too long of whips .
look......
By null at 2008-02-17
another
there you have it .i hope you enjoyed the trip thru the wilson 5000 coil.
dremel.....get one!
what ?the outer cover?no way ,those are glued on .
and if your talking about the center section i never looked into it that far .but i will next time .
hi guys,i am new here. i cought this thread about the wilson coils, i have been having problems like the ones you described with the 5000 coil with my 1000. the problem i am having is the swr is fine from channel 1 to 37, then from 38 to 40 when you first key it goes to 1.2.1 and then jumps to 2.4.1. this is with running about 120 watts. i don't notice anything that is loose. i was also thinking of disecting it to see if it could be repaired not sure how to go about opening it up. any ideas? thanks,
Bandit35
