Is There Anyway to Identify A Saturn Base Radio by its Serial Number?
danmcclain
I Support WorldwideDX.com!
Dec 11, 2020
1,284
802
123
75
I'm trying to identify the version of a Saturn Base Station that has no Model tag on the back of unit, just a serial number which is 022083. Help please... Dan
Only thing I can think of doing is comparing it with other pictures of the saturn base radios off google images.
Hi Dan. You may need to pop the cover and get the board number / version which is silkscreened on board for others knowledgable to assist. I had a saturn in the past and needed to confirm this info when i was looking for help with it. Hth 73 Jeff
Reactions: AudioShockwav
Thanks for the info... Dan
What are you trying to figure out Dan?
I guess I'm on a wild goose chase, was trying to identify the version of Saturn that a friends radio was to get the proper info on it. But since none was made available, my search is for naught. Thank you everyone for your input... Dan
Reactions: doffo
If you can get him to open it and identify the main board something like a ept360014b or the like it is the same as many other models.
All the service data can be had with the board number
I beginning to think this guy is a wanna-be tech....Instead of tracing circuits he's swapping parts from other radios... This is what he said about the pc board number: Board says SONG U TL-1
The 6-digit serial numbers indicate a radio pre-Y2K. First digit is the last digit of the year. Makes this one sound like 1990. A glance at the MC145106 PLL chip inside will reveal a 4-digit date code that can narrow this down.
Older versions of the S042P transmit-mixer chip will also have a 4-digit "open" date code. Two digits for the year, followed by the week 01-52.
After Y2K the radio's serial number format changed to include a letter identifying the factory. "M" for Malaysia, "T" for Taiwan. Pretty sure the "first digit" or "first 2 digits" rule applies to those radios as well.
If it's old enough, the "EPT"-prefixed circuit-board number may in fact start with "SRT", followed by the four digits "3600" followed by "10A". This will be printed in copper foil on the solder side, usually right next to the TA72222 audio-power chip.
Like this:
Reactions: doffo
Like this:
Thank you for the info.... Dan
