It’s just an antenna
nfsus
Yeah its turned off, touch it
May 9, 2011
592
319
Arkansas
I’ve spent lots of time effort and money playing with stupid antennas. Taking down free ones and rebuilding them or picking up new ones. It don’t matter from what I see. A stick is just a stick. But let me explain.
End fed verticals. Straight up in the air sticks of aluminum is what I’m talking about. Just plain ol 5/8 or 1/2 wave with or without a groundplane. They’re all the same.
So many feet of element. Some sorta matching device maybe. Some groundplane elements maybe. It’s all the same. And I can’t get around it. It is what it is.
No matter the brand or design the only thing that changes is the same stuff. Power capabilities, different groundplane design, material thickness, a different mount, maybe a different flux capacitor. That’s it. They’re all the same. A 5/8 is a 5/8 is a 5/8. Plots are all the same. Just are what they is.
And that sucks. I want better. Get higher get lower. It matters but it don’t. Ground is the only real improvement. And who has time or space to burry 250 radials in the yard?
I use an Astroplane. I like it. But for kicks I ordered a 5/8 groundplane just because I had an extra $100 just lying around. Even though I know it won’t do any better locally. Sirio gpe27.
Well that’s my bitch session.
There's nothing special about end fed 5/8waves,
some handle more power,
some handle higher wind speeds
some decouple the mast/feed line better than others,
I am sure we got to the bottom of where the mythical gain claims over 1/2waves came from on here years ago,
5/8 could be described as a 1/2wave of wanted radiation raised 1/8wave higher above ground by 1/8wave of unwanted out of phase radiation,
you lose some of what you gain by raising the current maxima higher above ground due to the lower 1/8wave been out of phase with the upper 1/2wave,
& end up with a little less low angle gain than a dipole installed at the same tip height :oops:.
The tornado came in. It sucks. Just staying with Astroplane. The screws won’t tighten. Ground plane rod fell out. Top fell in. After 3 hours.
And noise my god the noise. Tuned good but ugh
The tornado is an open circuit antenna with weak ass sirio construction, The 827 is shunt fed & far sturdier,
I would much prefer the astroplane at the same tip height,
For best results Isolate the mast a little over 1/4wave below the hoop & choke the coax at the same point,
The info about the best place to isolate the astroplane is posted on here by The DB(y).
I have a few myself but the temporary Frankentenna has been in the air for nearly two years now. I spot antennas and I have to have them. Like you, broken or not and that's how I ended up with the Frankentenna.
I was just getting back into radio and a Maco v5000 I had my eye on took a tumble in a thunderstorm and it became mine. The Hygain CLR2 I put back in the air after 20 years of sitting all of a sudden spiked SWR. It had a split in the load coil. I decided to use the base of the Maco and the mast of the CLR2 with an extra radial to the top hat to match the ground radials and she was ready. I can run 26.775 - 28.885 under 1.5. All the same? It is what "You" make of it. I hope you enjoy your new edition. ✌✌
