Okay, so I got my supposed "JB12" in the mail today. Turns out it's a JB150. The older one with the 6AQ5A keying tube. Had an RCA 8417 tube in it. After repairing a few broken solder connections inside and replacing the keying diode (1N60P, was 1N34A, and was broken) I talked on it for a while, all seemed well. I noticed that at some point the 8417 was glowing pretty red hot, I unkeyed it went down, it never glowed hot again. Output dropped from 100 watts to 60 watts.
So I thought maybe the tube was just bad, so I pulled a 8417 from my JB-200A and put it in there, keyed right up, 125-150 watts. So I think it's okay, I keyed it a few more times, noticed the tube glowing really hot on one side only, unkeyed, tube still glowing... Finally reached over flip the power switch off, glowing goes away immeadiately, let it sit for a buit turn it back on, everything is cool, sitting there idling, haven't keyed it up yet, wait about 2-3 minutes, no problem. THEN I key it up, and it works like normal. I unkey. I start to notice the glowing in the tube after I have unkeyed it is getting brighter and brighter, and I am not even keyed up... So I turn it off before it boils the tube. What the heck is going on here? Something sticking with the relay? Some kind of oscillation?
Help. I don't want to destroy my good 8417 tubes, so it's turned off till I figure this out...
