JCD-201-M
BigLou
May 15, 2018
321
329
SW FL.
Has any one wired this mic to a anytone 6666 or COBRA 4pin mic. I need the color of the wire to pin only. Thanks
Never heard of it. Don't have any wiring info on file.
Always used a continuity test to establish what each wire does. Mike cords get replaced. Usually the colors of the new cord are different from the factory cord. Learned not to take wire colors for granted.
First detail to establish is which wire is audio. Most of the time this is easy, it's the one with a shield wrapped around it.
Checking for continuity between pairs of the other wires will eventually reveal two of them with continuity. Doesn't tell you which one is for receive, you just know it's one of them.
Choose one of those two wires now, we'll call it "wire one". Checking from wire one to the remaining wires with the mike keyed may or may not get a continuity reading. If not, wire one is for receive.
And if you DO get continuity to another wire when keyed, that wire is transmit, and wire one is the common wire for transmit/receive switching. This would leave the remaining one of the first two wires as the receive wire.
And if the cord has only four wires to begin with, the shield will be the one and only ground connection for audio, for receive and for transmit.
Cobra:
Pin 1 is audio ground AND keying-circuit ground. Some mikes have only one ground wire, others have a separate one for transmit/receive switching. If so, they both go here.
Pin 2 is audio, the wire that has a shield around it.
Pin 3 is transmit.
Pin 4 is receive.
Undocumented "orphan" mikes are just too common. Learned to cope with a lack of proper instruction info.
Reactions: sunbulls
A quick Google search for this microphone model number turned up this information from Copper Electronics.
When wiring the JCD-201M to each of my test radios, the very first thing I noticed was the wiring diagram in the owner?s manual is incorrect. The correct wiring connection schematic is- 1 (E) Shield ? Ground 2 (M) Brown ? Mic audio 3 (P) White ? Ground 4 (G) Green ? PTT + 5 (U) Black ? UP 6 (D) Yellow ? DOWN 7 (C) Blue ? UP/DOWN Ground 8 (B) Red ? 5-9 VDC power +
Link to this information:
https://www.copperelectronics.com/cart/Microphones-CB/Base-Microphones/JCD-201M-Base-Microphone
Attached below is the Microphone manual found on BOB's CB Shop Website.
The stock Anytone AT-6666 mic wiring at the radio side of the plug is:
1-Audio Input
2-Shield
3-PTT
4-N/C
5-Ground
6-Vdc in RX and TX
Microphone wiring found at the link below. Thanks Google!
https://simonthewizard.com/2019/01/08/schematic-anytone-at-6666/
You're Welcome.
David
Looks like this mic doesn't have a rx wire, which would be grounded during rx and opened during tx. The ptt wire is opened during rx and grounded during tx. If radio audio (cobra 29, etc) routes thru the mic, that won't work. You could transmit but not receive. Gotta figure a relay would be needed, controlled by the ptt line, NC of relay to rx pin of cobra 4 pin, NO of relay to tx pin.
