Johnson 5 pin spike mic plug ?
bevis
Sep 28, 2020
65
24
18
60
Does anyone know where you can source the weird 5 pin johnson mic plugs ?
The pins are spike tipped. I have been looking and coming up with a blank.
I have a couple of johnson 250's and i need those mic plugs.
Are they out of production ?
Try ebay and type : CEA-CB5DF twist-lock 5-pin DIN mic plug Craig Johnson CB's, Regency Polaris VHF
    • Fits Johnson 40, 50, 80, 230, 250, 260, 270, 430, 4170, 4175 CB radios
Good luck
If memory serves, this is the right one.
https://www.ebay.com/itm/264480185572?hash=item3d943f5ce4:g:4igAAOSw11ddjrhl
This radio has six-wire mike cord. On a 5-pin plug? The metal shell of the plug is the ground connection for the receive speaker, but only when the ring is clicked into place. Just plugging it into the jack with the ring loose may or may not work every time.
I just bought that one from that link. It was his last one.
Thanks for the heads up !
Reactions: tecnicoloco
