Johnson Mouse-enger 250
saturated
Can't find my ass with both hands....but I'm here
I Support WorldwideDX.com!
May 6, 2026
56
56
18
63
Hello everyone hope things are going well
I thought I would see if you guys thought I could get this Johnson Messenger 250 going.
Fortunately most of the damage seems to be on the top of the case it's a shame this seems like good stuff because this sucker is heavy and I have the mic for it as well.
It refuses to power on and the fuse is good
Opening up this unit shows evidence that someone modified or deleted and or added some parts for what reason idk
Where the two big diodes? are it looks like they uh...yeah idk here's a close up
If you think it's worth it he effort I can get a Sam's for it and try to scare up the missing components.
I have not tried to check the transformer or power supply as of yet so I apologize honestly I got nothin at the moment
I just remembered I have a 13.8 V realistic power supply I can try on it.
Whoops sorry I guess it does power on
The lamp above the meter does illuminate just barely discernable
Hope is growing :coffee::giggle:
Maybe all it needs is a recap and clean. If you decide to repair it, see if @danmcclain has a Sam's in his thread....
Anyways, keep us posted and good luck.
Reactions: saturated
At least it's decent looking on the inside for its age. These were real audio monsters with a Johnson base power mic. I believe there was a mod you had to do inside to open up the audio.
I have Sam’s 60 for the Johnson Messenger 250, but give me a few weeks to post. I usually take that time to enhance the manual and splice the schematic together. Meanwhile, CB tricks has the complete manufactures version, and a small service bulletin component change that will improve the tone quality from the speaker.
Yes sir thanks wow that is very generous of you i definitely appreciate it
However I went ahead and ordered one from eBay it's otw seems like certain issues tend to be a little scarce.
I think I know the answer to this question but I'll go ahead and ask
....I guess I can forget about finding any axial capacitors ?
Also (I know I should have asked first :sick: :mad: ) I bought some old carbon comp resistors then later reading sometimes they don't hold up so well.
Oh well only one thing to do...just check em when they get here. :coffee:
Before joining this excellent community I thought hell what's a resistor any old one will work :oops:
Also since this thread got bumped I wanted to take time out and say I imagine that the brain trust here accumulated their hard earned knowledge through a lot of hard work blood sweat tears (and smoke) and many still work in this field professionally $$ so I very much respect confidentiality and strive to use discretion when welcoming advice and suggestions (y)
Also thanks to anyone willing to help I don't want you to expend additional effort but I'm only suggesting if you think you recognize a problem maybe drop a hint (instead of "yep change Q302") like maybe point in a direction and say hey ya might wanna be looking in this section so I have to get off my rear end and do some work (and learn something) :LOL:
You can, but expect to pay, sites like antiqueradiosupply come to mind, but I think they changed names. See..
I usually opt for the metal foil high tolerance resistors, very close to the price of carbon.
You're already supporting the site financially, the only other thing I can think of is dive into this community and better yourself. Then you can chime in and help others like yourself.
Here is the info from sams cb-60 for johnson messenger 250... Dan
This is an example of what I do whenever I replace those Axial caps. I usually measure the distance between the mounting holes to approximate the lead bends before mounting the cap vertically. There should be plenty of room to mount those smaller caps vertically in your base. That is not always the case in some early mobiles where the speaker often gets in the way. If there is not enough room for a large cap, mount the Radial cap horizontally, but that usually requires extra lead length with slip over lead protection. In either instance, I always hot glue any large caps to the board to keep them stable.
So far I finished the schematic. It will be easier to read and follow on a wide screen monitor if you have one.
Hey guys how's it going
Being a noob I still forget things and I remembered today
WHY DONT YOU TRY IT ON THE EXTERNAL DC POWER......DUMMY :ROFLMAO:
So I did. I was a bit befuddled by a single blade sticking out the back. Oh well onward through the fog aye matey :LOL:
So incredibly I located a female spade connector that fit and crimped it on
I was scratching my head why not a place to connect ground :unsure:
I rationalized that well if I connect pos voltage it will find its way to ground hell that's its job
And....it didn't work
So I looked again for a place to connect ground and said well hell I'll just make my own
And with that we came alive (party)
Unfortunately there is not a peep of sound
The only sound I get is if I key the mic when I let go I get a decent pop.
I next tried the PA it did not work.
However when I connect an external speaker it works good
And still no receive sound with external speaker.
I have an antenna connected and I exercised squelch and channel select so idk.
I know there's probably some work to do of course but I'm glad I had enough snap to try some things and get some evidence before doing surgery
So I'm pretty stoked thanks for listening
Sorry nothing to see here pardon me for putting this here just adding this for my own records before I start a hectic day of non radio BS :mad: :ROFLMAO:
Anyhow I tried a test receive experiment just dialed rf to about 27 Mhz modulated one khz and went looking for it
Found it on channel 18
This time I had enough sense to hook up the frequency counter and take a gander
The audio is pretty weak
But seems this is encouraging enough :cool:
Maybe with a little luck and a few components she'll be up and running
I know
WELL WHAT THE HECK ARE YOU WAITING FOR :ROFLMAO:
Well I hooked up both radios with mic and antenna and got some encouraging results
The Johnson 250 can hear the Craig 4201 on multiple channels :cool:
Unfortunately if I try to talk to the Craig 4201 from the Johnson 250 it sounds like the Craig is receiving just silent rf because the static stops whenever the Johnson mic is keyed.
So I've got some homework to do
Also I got my Sam's out and took the cover off the Johnson and started poking around with a new sense of motivation
I looked at the list and saw there was a six volt capacitor but got scared when I saw it
It's that silver doodad in the middle with the red on the end
Not sure I want to mess with that guy :oops:
Then another sickening dose of fear when I saw these creatures :eek::oops:o_O
The ones that look like rectangular capacitor cookies
Oh yeah then those axial capacitors the three paint dots on em.
... I think I know the answer to this question but I'll go ahead and ask
Welcome aboard! I have a capacitor kit for this radio.
https://klondikemikescapkits.com/products/e-f-johnson-messenger-250-electrolytic-capacitor-kit
