Kenwood Hand mic wiring
JLsenior
Sep 11, 2018
22
3
13
44
I want to hook up a 4 wire kenwood external mic into a cobra 29 4 pin connector.... any one know.....not just guessing?20200402_102717.jpg
JLS,
What is the model number of the Kenwood microphone you are using? Or what model of Kenwood transceiver was the microphone attached to "in a previous life"?
Helpful to know as some electret condenser microphones require power from the transceiver to operate. If your Kenwood microphone is one of those, it could complicate things trying to wire it up to your Cobra 29.
It appears from the picture supplied that this is from a handi-talkie. Looks like it has a speaker and microphone in it. You may be able to get the microphone portion to work(but will require a low voltage source from the Cobra 29-not already supplied at the microphone jack) but probably won't get the speaker function to work without some major reworking of the internals of your Cobra 29.
Speaker=Red Arrow, Microphone element=Yellow arrow
David
