Keying Circuits for sweep tube linears
Rhinoky
Jan 31, 2021
20
16
13
56
Hello all, I am trying to help a friend find info on a keying circuit for a sweep tube style linear. I was told the transistor used for a tube style linear was different than that for a transistor style linear when building a keying circuit? For instance, I was told he needed a darlington style transistor where the other linears use something like a 2n3906, 2n2222a or a 2n2905a. Does anyone have any info if this is true, or what actual transistor would be needed for this keying circuit for a sweep tube box?
Thanks in advance,
Gary
Here's some circuits from pg. 348 of the 1984 ARRL Handbook.
Or you could just take the path of least resistance and buy one ready to hook up to your relay and input jack. (Shameless plug department)
https://www.ebay.com/itm/1173209701...pid=5336136228&customid=&toolid=10001&mkevt=1
It's set up for positive 12 to 24 Volts DC coming out of the standby switch and into the relay coil. Some older sweep-tube boxes used a negative DC power source for the relay. Our board can be used for this but it's a bit less convenient that way.
Hello Naysayer,
yes... if it were for me and needed just one I'd buy it in a blink, but the guy is learning to repair/build amps himself and needed to know what transistor(s) would work for the job. Thanks to Nomad posting the link to the ad on his Ebay site, I found the info he needed. It is a Darlington PNP as he thought. Nomad has them listed in the last image at the top of the page in the ad.
Thanks to all,
Gary
