KLV 550 Base amp (recieve Amp problem)
TonyV225
Apr 18, 2005
5,824
323
143
Wisconsin
Ok I have a KLV 550 Base Amp that the recieve or Pre Amp does not work at all its a variable knob that lets you control how sensative you want the recieve to be. When turning the preamp on it does absolutely nothing. I was told its usually a transistor a TO???? anyways when following the wires from the preamp to the board the only visable transistor thats near that area is a L7824C-V
W993E91727
MALAYSIA .....Does this sound right as far as being the transistor I need to check or replace??
