Lazer 400 set up questions
  • Thread starter Thread starter hossless
  • Start date Start date
H
hossless
Guest
Hey all, I recently traded for a Ham lV rotor w/control and a Lazer 400. I sold my Moonraker 4. I will be setting the 400 Lazer up for horizontal operation only, and will not be installing the vertical elements. Do I need to make any changes in the spacing of the elements when only assembling for single polarity? I see Maco sells a M106C which is a single polarity six element antenna, is this how I should set the spacing of the elements, or should I stick to the Lazer specs?
Thanks, Hossless
</p>
hossless,
The simplest answer is go with the Laser's spacing
and don't bolt on the vertical elements. Without
changing the boom length varying the element spacing
won't make a lot of change for the 'better'.
</p>
10-4 Doc, that's what I was leaning towards, but wanted feedback. I'll go the Lazer400 spec route, and if things need a wee bit of changing - that's easy too.
Thanks man, Hossless
</p>
Thanks 2020, I'm gonna' stick with just flat side though, and I'm hoping this Lazer400 does even a better job puttin' the maul down than that Moonraker4 did. I only had the Raker up about 21' and it did an awsome job tx'ing and rx'ing, this baby will be up about 43'...
Hossless
</p>
