Lincoln TX problem
Rogerbird1
Well-Known Member
Apr 24, 2002
526
139
53
Massachusetts
rogerbird1.20megsfree.com
Hello,
I hope I can shed a little light on this.
It is possible your TX troubles are caused by a bad Capacitor.
There are a couple in the radio that are low rated.
10v instead of 16v or 35v capacitors. They can go from slight pwr surges or from 'Old Age' because they are in circuits that run at very near to 10v. (typical Tolerances suggest these should be rated 2x to 3x the operating voltage)
So much for the WHY..
I suggest you check or replace C75 - 10v 220uf cap with a 16v or 35v 220uf cap. This cap is on the supply line of IC104 which in part is the TX Control IC.
See the 'New' IC Voltage Charts on my site for more info.
( Rogerbird.tripod.com/ )
Ic Voltage chart
See the voltage at Pin 1 of IC104 (TX 7.6v, RX 7.2v ) , Pin 8 is the TX Control pin feeding Q136,
E C B
Q136 Tx 0.0 0.0 0.7 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp
Rx &nbsp &nbsp &nbsp &nbsp 0.0 8.0 0.0
then Q125 (TX 8v Switch )
E C B
Q125 &nbsp &nbsp &nbsp &nbsp Tx 7.3 7.8 8.0 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp
Rx 7.4 0.0 8.0
My 'guess' is that C75 is shorted and not providing voltage to the input of IC104.
For a great board layout of the Lincoln/hr2510 go to:
Cbtricks HR2510
I hope this helps..
Roger
</p>
Hello,
Ic Voltage chart
E C B
E C B
Rx 7.4 0.0 8.0
Cbtricks HR2510
I hope this helps..
Roger
</p>
I have a 3 year old Lincoln with,unfortunately,the old 477 in it.I have taken it to a tec about 60 miles away in Hull,UK,because although it was receiving,when the mic was keyed,it wouldn't cut over to transmit.
They can't understand what is wrong with it,and I haven't a clue because it was working about 4 weeks ago before it was taken out of my truck,and put into storage.
Does anyone have any thoughts as to what is wrong?
Ken. <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/frown.gif ALT=":(">
</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=quinny1>Quinny1</A> at: 1/10/04 8:54 am
