liquid cooling system
The tubing and heatsink might work, but your gonna probably have to use copper tubing. And since the bend radius is so tight have to use a 1/4" tubing and special fittings. Depending on the size of the amp, your also going to need a big condenser/ radiator to pull all the heat out of liquid. Plus use distilled water. Will help eliminate buildup in pump and lines.
Reactions: walterjn
