Little problem- trc-449 nb/out switch
jrd426
I Support WorldwideDX.com!
Sep 5, 2018
275
206
53
57
Hi Guys, hoping someone can help me out (maybe even a 449 owner :) I picked up a 2nd hand 449 am/ssb mobile and some previous owner has used the nb/out switch for channel mods. I would like to remove this mod and put the nb back to stock. My problem is what to look for to reconnect. Can someone tell me what their wiring looks like on that nb switch. I'll look for a schematic in the meantime and see if I can figure out where the far end of this wire terminates on the board and try and find the original wire that way.
Thanks guys
Thanks for the link. Being not much of a tech I'm hoping to match up a clipped wire in the general area of the nb switch. I asking a more technical friend to look at the schematics to help maybe. I have a brown wire with a white and red wire inside. Just clipped and sitting there which may be what is needed to go back to the switch. Thanks for your message
The ANL/NB switch should have 2 sections of 3 terminals, arranged vertically.
The brown wire with red and white wires are most likely the AM mode ANL side of the NB switch. One should go to the down lug of one side of the slide switch, other should go to the center lug of the same side, just above. Down (off) shorts across the ANL, thereby disabling it, up enables the ANL.
The NB should be 2 more wires, maybe taped up, one wire goes to the center lug, and the other wire goes to the upper lug.
ANL ---- NB
N.C. -- | | -- To NB wire
Red -- | | -- To other NB wire
Wht -- | |
N.C. - No Connection
The red and white wires are interchangeable, so long as they are on that side of the switch.
Reactions: Woody-202
Thank you NZ8N. Very much appreciated.
Best you you and your family over this holiday season and for 2020.
Cheers
