"LIttle Tar Heel" Screwdriver
  • Thread starter Thread starter CW Morse
  • Start date Start date
C
CW Morse
Guest
I had a visit from a friend today who bought a L'il Tar Heel antenna (mini-screwdriver) that covers 75 thru 6 Meters with a
36 (?) whip and 160 thru 6 with about 56" whip--even more with a longer whip, but you just lose the upper bands. I had never messed with the mini-screwdrivers, but they DO work, and for someone that just won't abide a full-sized screwdriver, not a bad compromise. Shouldn't notice the difference above 40 Meters. We checked into the ECARS net on 7255 and got a great report from PA. He had never fooled with a screwdriver before, and got me to show him how to resonate it. The min-screwdrivers, as I said, are a good compromise and should do quite well for someone who wants a short antenna (less than 6' total extended), or the XYL won't let 'im put big ugly antennas on his vehicle They will not perform as well as the larger HF antennas because they use very small gauge wire wound on a small form. They won't accept much more that a couple of hundred watts without melting down--which really is not an issue for most of us. The serious HF operators running 75 Meter mobiles will usually have 2 or 3" bugcatchers or screwdriver antennas wound of #14 wire at 8 or less turns per inch. (Like the ones *I* make<img src=http://users.joplin.com/dutch64804/wavey.gif ALT=":wavey"> ) LOL!
But if you are mostly an occasional HF operator that works 75 meters rarely, the little Tar Heel and other smaller screwdrivers work quite well above 40 Meters.
CW Morse
</p>
I had the Little Tarheel II antenna for some time on my Jeep. You're right...they do work pretty good above 40 meters. It's an excellent choice for someone that wants HF while offroading as has such a small footprint and weight load. I bet it would work great on a car, as well. I found that 40 meters was a challenge unless band conditions were pretty good, and of course 75 was worthless. I ended up selling it to buy a big 4" coil HiQ antenna because I wanted to be able to run some more power (which I haven't acquired yet). I really wanted to keep it so I could put it on the vehicle while in the sticks so I may get another one some day if I find one at a good used price.
</p>
I used the High Sierra with great results on 75 meter www.cq73.com The longer the antenna the better you do on the lower bands but like mentioned you lose the upper portions, 6 meter, 10 meter and so on the longer you get. I have the 1800 pro with a 6 foot whip, I put a MFJ 108 inch whip on and sure it was easier to tune 75 meter but that friggin whip is ,,,,,,,,,,,,well just that a WHIP it was all over the place going down the highway! I went back to the 6 foot whip. High sierra also makes a mini version like the tar heel. I prefer the High Sierra myself. I am going to mount the High Sierra on my tower one day and see how it works but right now the 9 inches of snow we got last night kinda puts a hold on that <img src=http://home.comcast.net/~shockwav/smiley_155.gif ALT=":jmpnsmly">
</p>
    boog351 has left the room.
