Live Webcam Stream From Houston TX
DJboutit
468
48
CB Radio webcam stream 2 webcams on feed one cam is pointed at my Imax antenna other cam is pointed at my Cobra 142gtl with audio. The webcam outside is a Microsoft Lifecam Studio the cam point at my radio is a Logitech C615 the C615 I can not used outside with a decent amount of sun white balance sucks.
http://original.livestream.com/djboutitslounge
Here are my first to streams
Watching a radio is kind boring you really just need the audio. The antenna cam you get to see more that just the antenna.
I know this is an option, but afaik these camera's can't be controlled by default webcam drivers. The idea is to run the camera through a web service without the need for 3rd party programs.. suggestions?
CB Radio webcam stream 2 webcams for pc on feed one cam is pointed at my Imax antenna other cam is pointed at my Cobra 142gtl with audio. The webcam outside is a Microsoft Lifecam Studio the cam point at my radio is a Logitech C615 the C615 I can not used outside with a decent amount of sun white balance sucks.
Only time I could get anything other than I-10 when living around Houst, was by getting away from it. Used to be able to go out off Bolivar, TX City Dike, or some out of Hitchcock and receive. End of Redfish Rd. had a water tower and couple houses.
  • @ heartbreaker3473:
