Longest Power On?
Peter Walker
Feb 23, 2011
119
60
I was wondering what is the longest time any of you have ever left your radio on? I set mine up to scan the 10 Meter frequencies that I can talk on as a Technician and was wondering if there is some general guideline that should be followed as far as how long a radio should be left on.
Scanning on 10? SSB? You have to have your squelch up to scan. If you do that you'll a miss a LOT of smaller signals out there.
You can leave your radio on all you want. That's what it's made for. To turn on and use.
Good luck
If you are going to leave that puppy on all the time - you better make sure it has plenty of air circulation around it (vs stuck between rigs, books, etc.).
I used to have a Siltronix 1011D. When I brought it home, hooked it up and finally turned it on...it stayed on till I sold it ...the only time it would get shut down was during thunderstorms or when I would be gone from house for a few days..
I am currently running an Icom 736...and I have left it on for days at a time for one reason or another with no ill effects that I can tell....Just be sure you have a good air flow around radio
I have an Icom 2720 that is on 24/7 365 with an small beam antenna in the attic, also our club repeater's are a pair of Alnco they are also on 24/7 365
