Looking for Owners Manual and Service Manual for a GB 150 Solid State Linear
danmcclain
Sr. Member
I Support WorldwideDX.com!
Dec 11, 2020
1,301
819
123
75
Looking for any and all information on a GB150 Solid State Linear pictured below....Thank you.... Dan
Might be more here
Thread about the mobile, the base has a crude un regulated power supply.
Dan, I have never seen a service manual for any Grey amp.
There is a thread here somewhere that talks about one but they were like most CB amps back in the day.
I will look for the thread
Jeff thanks for the info... Dan
Nomad I am sure is familiar with these
Yep. The toroid power transformer is woefully undersize. The DC voltage on standby is over 20 Volts. Drops to around 12 under load. The high standby voltage tends to cause RF transistors to fail, frequently as you unkey. We learned to insert a 30-Amp "Bosch"-type automotive relay between the DC power and the amplifier board. Added a transistor to carry the load of the added relay's coil, and drove the transistor from the original relay circuit. This will remove DC power from the RF transistors in receive mode.
It's a bit like a small mammal. High metabolic rate, short life.
Thank you for the info... Dan
