LQQKING to purchase a clean 2 pill for SSB use
DXcarpenter
Dec 6, 2017
23
37
23
57
Hey guys.. I'm kinda new on this particular forum. So I'm still trying navigate proper and figure things out.... I just recently put up a base station.. And was looking to buy a clean AB1 output amp.. I used to run a TS 400HDV but that was over 20 years ago... I've heard the new ones are not as good with Chicom parts and what not. I was looking at the TS 350.. Can any of you's direct me in the right place for a smooth, reasonable price, good customer service business transaction? If I do get a mobile amp, I will need a good ballsy power supply as well... Any input from you guys would be much appreciated..
Thanks
Thanks
I hate to say it but you'll be much better off going with a reputable builder than most of what's mass produced out there. It'll cost a living but that's just the cost of a good amplifier these days. Not sure if the Tin Man in the Bam is still building but that would be my recommendation. I sold a tin man to a forum member here and he's had nothing but good to say about his work too.
Thank you for some input on my inquiry.... I appreciate that.... I'm in no hurry,, but was seeking some wisdom from radio enthusiasts here on the forum... Thanks again.
I got a good deal on a new TS-350.. Want to send it out to get hot prodded.. Toshiba pills, thicker gauge wires etc.. Looking for a tech to do the task? Any input would be appreciated..
Thanks
Reactions: Eldorado828
Sorry about the Typo.. Hot Rodded... Any techs you know of willing to work on amp would be much appreciated .
Thanks
Thanks
Most any tech worth his salt is backed up for 6-7+ months . A TS out of the box will do fine as long as you don't beat the breaks off of her. Adding Toshibas is going to be a $200 per transistor investment minimum (2879s). Donkey Stomper makes a good amp, he'll add bias for a little extra change and it works great, I own one of his 1X4s and she sounds excellent on SSB (so I've been told).
This is his current price list.....
Donkey Stomper Mobile CW Amp Pricing
100V-HG-1 Transistor $215.00
200V-HG-2 Transistor $295.00
300V-HG-1x2 Transistor $400.00
400HD-HG-4 Transistor $475.00
500V-HG-1X4 Transistor $575.00
550V-HG-2x4 Transistor $650.00
600HD-HG-6 Transistor $675.00
700V-HG-2x6 Transistor $875.00
800HD=HG-8 Transistor $900.00
1000V-HG-2 x 8 Transistor $1,000.00
1000HD-HG-10 Transistor $1,100.00
1200HD-HG-12 Transistor $1,295.00
1200V-HG-2x12 Transistor $1,475.00
1600HD-HG-16 Transistor $1,675.00
2400HD-HG-24 Transistors $2,600.00
3200HD-HG-32 Transistors $3,500.00
4800HD HG-48 Transistors $5,000.00
6400HD-HG-64 Transistors $6,500.00
Donkey Stomper CW Base Amp Pricing
200VB-HG-2 Transistor $500.00
300VB-HG-1x2 Transistor $625.00
400HDB-HG-4 Transistor $875.00
500VB-HG-1x4 Transistor $950.00
550VB-HG-2x4 Transistor $1050.00
600HDB-HG-6 Transistor $1200.00
700VB-HG-2x6 Transistor $1450.00
800HDB-HG-8 Transistor $1,450.00
1000VB-HG-2X8 Transistor $1,650.00
1000HDB-HG-10 Transistor $1,900.00
1200HDB-HG-12 Transistor $2,300.00 (2-units)
1200HVB-HG-2X12 Transistor $2,400.00 (2-units)
1600HDB-HG-16 Transistor $2,900.00 (2-units)
2400HDB-HG-24 Transistor $4,000.00 (2-units)
3200HDB-HG-32 Transistor $5,000.00 (2-units)
48000HDB-HG-48 Transistor $7,900.00 (2-units)
6400HDB-HG-64 Transistor $12,000.00 (3-units)
External Pre-Amp Works Base or Mobile $145.00
Single Remote $65.00 Dual Remote $85.00
Add Class B Biasing 2Pill-$50.00, 4Pill $75.00, 8Pill $100.00, 12-16 Pill $150.00
Super upgrade add $30.00 per transistor to upgrade to HG-2879C-150 watt transistors
Donkey Stomper Power Supply Pricing
40 Amp $300.00
80 Amp $500.00
120 Amp $600.00
160 Amp $650.00
200 Amp $800.00
240 Amp $900.00
320 Amp $1,000.00
400 Amp $1,300.00
480 Amp $1,350.00
560 Amp $1,700.00
600 Amp $1,800.00
800 Amp $2,600.00
1000 Amp $3,200.00
All Power Supplies come set 12.5-15.8 volts customer’s choice.
All power supplies come with a Volt Meter.
Thanks
Best bet on that new TS350 is have a tech make sure it's at a 50 ohm impedance. Then upgrade the power cord to heavier gage. Beyond that there is not much to "hot rod" as you put it. Just run it and don't over drive it. Toshiba finals for that amp will be stupid expensive.
Reactions: Ranch55
Very informative info from you guys.. Thank you for that.... And by the way.... I burn tires on my Dyna FXDLR not on amps... I'm not looking to get out farther... Just want something sounding clean when I'm DX'n... I've been out of the loop for many years and just needed some input.... Appreciate it.. Thanks
73's
40 Amp $300.00
80 Amp $500.00
120 Amp $600.00
160 Amp $650.00
200 Amp $800.00
240 Amp $900.00
320 Amp $1,000.00
400 Amp $1,300.00
480 Amp $1,350.00
560 Amp $1,700.00
600 Amp $1,800.00
800 Amp $2,600.00
1000 Amp $3,200.00
40 Amp $300.00
80 Amp $500.00
120 Amp $600.00
160 Amp $650.00
200 Amp $800.00
240 Amp $900.00
320 Amp $1,000.00
400 Amp $1,300.00
480 Amp $1,350.00
560 Amp $1,700.00
600 Amp $1,800.00
800 Amp $2,600.00
1000 Amp $3,200.00
I did manage to get in contact with Chad from Stomper.... We got deal handled.. Thank you for the 411.... Moving right along... I do have another request.... I'll post it on another thread.... Thanks again..
73's
CDX 501
Its not just the cost of the pills but everything has to be changed. TS is using crappy dei pills and you cant just pull the dei and drop in toshibas.
Personally I would've called Carl the founder of Xforce who is back building under the Carl Built name.
And yeah, toshibas are or can be $200 + each and dont fall for the $50 chinese fake toshibas.
