Mic cord sleeve
H1driver
I Support WorldwideDX.com!
Feb 13, 2011
145
192
53
What is the best thing to use for a sleeve on the cord when installing a mic jack on a small diameter cord? The cord is the same size or slightly less than the plug even fully tightened. The strain relief boots I find are not made correct for this. Does anyone make tubing specifically for this? Thanks for any information.
Some guys have said they use stacked up heat shrink but I personally found that gutting a black 3 wire extension cord and then using that jacket works great as well as looking original. Wallyword sells a 6' black extension cord for about 5 bucks which is what I used.
Just my $0.02
