Midland 13-893 AM/SSB - Low output power issue
FarmBoy72
New Member
Sep 27, 2018
5
2
3
33
I have a Midland 13-893 AM/SSB 23 channel crystal-synthesized radio that I'm having an issue with and I'm a bit stumped. It has a 4watt carrier on AM, but talking into the MIC and applying audio barely modulates the output, maybe gets 0.5 watts over the carrier with a loud whistle. In SSB its a similar story, has about 4watts max output when using the MIC. (Side note, this came from a CB shop that closed in the mid-late 1980s and the this radio was in the box of units with issues, so this radio has sat for probably 30 years)
To start, I went through and aligned the synthesizers, one of them had a very weak signal and the oscillator wasn't receiving full power, which lead me to my first discovered problem, a protection diode on one of the power rails was split open, so at some point somebody has flipped the power..... I replaced the diode and now all the oscillators are working properly. A few of the mixing crystals had drifted low over time and I had to swap out a few of the padding capacitors to get them in range of their adjustments. After that mess it now receives on AM/SSB. The receive doesn't seem to be as strong as it should be, the Photofact says to inject a 0.5uV signal for one adjustment but I had to bump that to 10uV to get output through the receiver. But I have no idea how calibrated my old Anritsu MG3601A RF signal generator is or if the output is still working that low......
So next, to try and track down the low output issue, I started at the microphone and followed the audio trail through both the AM modulation path and SSB modulation path. Everything seems O.K. all the way through, the signal was increasing through the AF amplifers. But I'm quite new to this so I don't have a great feel for the level the signal should be at in each point. I did hook up an 8 ohm speaker to the PA jack and the PA function drives a speaker and the audio doesn't sound garbled or off.
Other things I have tried is adjusting VR15, the RF power adjustment, and it doesn't make a noticeable difference in output on AM, but I can get about 8-9 watts in SSB whistling into the MIC with the MIC gain at maximum and VR15 at max travel.
Looking at the demodulated output and RF on an oscilloscope (through a home-made sampler) there doesn't look to be any distortion.
So that gets me to where I'm at now, I'm stumped. Any ideas??
Thank you
CB tricks has the schematic here
The alignment on this radio is just a little wacky. One set of tuning slugs in the crystal synthesizer is peaked for AM and LSB, the other set for USB only, IIRC.
Seems likely that the resonant peak setting for a handful of tuning slugs has drifted over the last 40-plus years.
Only step-by-step guide to alignment will be in Howard Sams volume CB-69.
Reactions: kaos513
Oops, I didn't explain myself well. I do have the pages from CB69 on alignment. I was able to follow them (after fixing the blown diode issue) and the 19mhz chain for AM/LSB and the 34mhz chain for USB are adjusted.
I also changed out most of the electrolytic, a large filter cap near the blown diode had some scorch Mark's on it. And quite a few 1uf caps are used to couple signals between different sections. Knowing this radio was in non cooled storage I felt it best to change those.
The radio receives on-frequency when I use a 30% modulated signal from my generator. Before alignment of the synthesizers, I had to max out the clarifier to get it to start receiving. All the Crystal's had drifted low and the slugs were a tad off. And I agree, the mixing scheme to get SSB on this is quite wacky.
I looked at aligning the 27mhx chain, and was able to follow the steps. I'll double check again, some of the slugs dont make a noticeable difference in output power but they did affect some of the spurious signals nearby. I have a spectrum analyzer, but it's only got a minimum 100khz/div with, I think, a 9khz bandwidth. So I can't see what the side bands look like and tried to adjust them to minimize spurious emissions. I dont believe I moved any slugs more than 1/8 turn.
Thank you for the help! (My end goal is to get this thing working on 27mhz, then set it up with an arduino and DDS to use on the 10m band for ssb and to learn in the process)
In cb tricks there's a power mod where you add a resistor parallel to a existing of the same value will enable this radio to be easily tuned to it's true max output.
My Midland 13-893 will tune as high as 31 watt carrier swing 35 average watts and peaks around 55 watts.
It doesn't seem logical with the type transistors in this radio tho it will heat them up real quick if you tube it that hi and throw a key down for 2 minutes or longer and I realize it's impossible to believe for I still don't believe myself except for what I seen on my watt meter while tuneing my 13-893 after the power mod it really did have a31 watt carrier and 35 swing at 100% modulation so I backed it down to a 10 watt carrier and it'll swing about 17 and still has a peak reading close to 40 watts peak.
I use my Midland 13-893 as a base station and my primary rig that's always powered on and use it everyday and so far it's a great radio I can't say one bad thing about it except for having to do a little crystal mixing so that I could get to channel 38 frequency 27.385 where I talk on LSB and this radio is just freaking awesome on sideband I am more than pleased with this rig
