Mobile amp wire size
Are you getting the feeling that you've been had? Well, yeah, but you gotta think about that a bit and figure out that you ain't exactly given enough information to really get a fair idea about what you ain't figured out, you know?
So, back up and start from scratch, sort of. What isn't working, what have you done, and where'd you goof. Howz'at for a start?
Nobody can help if you don't tell us what's gone one and so forth.
Depends.... maul watts, swing watts, or bird watts?...Also do you have an antenna like the Predator 10K that boosts your audio by chance? All of this will determine the things needed.
Wanting to know what is best size wire to run directly to battery for small amp in motorhome ? Would 20amp fuse be enough ? Any ideas where wire can be purchased already made up with ends for attaching to battery ? Any help would be appreciated.
555
You can buy 10' 10 gauge at advance auto or 8' 8 gauge. That is sufficient for a small amp. I've never had any problems with 10 gauge in 20 years. Put a vehicle protection fuse at the battery and your set. That's the short honest answer.
If you ain't mauling, your bawling
You ain't got a thing if you ain't got no swing
Needle in the corner, 10K slug, Bump Bump.
Ain't no doubt about it they call me World Wide, World Famous, World Renowned, Three Hundred and Thirty Nine working this 3 legged lady, my long boom flat side, And this Johnson technology and I Just got all the way down.
glass has class, but steel is real
I used a stereo amplifier install kit from Monster audio for my TS 350. Paid about $100 at best buy for it.
And Audioshockwav my favorite quote is ...stop cryin' and start buyin' and with 4 watts stop tryin'.
The scary part is that I don't think you had to practice that. :tongue:
Reactions: 2 people
Don't motor homes have generators? Run the generator and get a plug in the wall amp, then run a big linear.
Reactions: 2 people
