Thanks, Marconi.
So, it appears that I should shorten the vertical, and retune the gamma to match. I should be sure to choke the feedline (but at what point? Hard to tell on model). This should optimize my antena...?
I placed a 1 pF capacitor as close to the top of the radiator as possible. I did not physically isolate (ISO) the mast from the antenna. This only simulates the mast to showing no common mode in this case, it is not an actual choke.
If I add a Feed Line and isolated (ISO) the mast, that might be more similar to your antenna,
If you have been successful at fixing the CMC on your real Vector I would try the same setup.
If you are isolating your 6 meter were the mast would attach to the antenna, let me know the distance and I will play with getting the model to working with a feed line, ISO, and a simulated choke.
I'm not positive, but I seem to recall that DB, some time back, said he was using a coil choke at this point, but I've never seen this included on one of his models and I he didn't explain to me, what he did instead.
Maybe you could ask him.
I plan to try and get the physical gamma to work on your 6 meter model and I will start by using the 27?" x 1/4" inches that you suggested. I might take some guessing and trial an error. Maybe Bob has already shared or can share how he does his new project. I'll have to go back and see if Bob posted those dimensions already.
I might also find some need to correct some of the dimensions I calculated too. Sometimes with wires close to other wires the raw dimensions don't consider these effects.
