Musical Instrument Gurus
Wire Weasel
Senior Moment
Dec 13, 2008
3,264
928
223
What's another name for an instrument similar to a Chinese Bell Tree?
I'm looking at the round metal tube type ones arranged in a string horizontally, free hanging, and you strike against them and they give that sound like ice cycles hitting against each other.
What's the modern name for that...one that a current band would use?
Tubular bells?
Thanks for any help!
I have been a drummer for 30 years and yes what you are referring to are known as chimes Neil Peart the drummer from the 3 man rock group RUSH who is also known to be the best drummer in the world has a really cool set of chimes they go from huge to really small I dont know how he uses those little ones LMAO!! His chimes range in sound from a large church bell sound to the high pitch breaking glass that you refer to.
The smaller ones - with the cylinders less than 8 inches long or so, are generally called "wind chimes". The larger ones, with hollow tubes ranging from 2 feet to about 4 feet long are just "tubular chimes" to a classical percussionist (like me).
The ones with metal bars mounted horizontally like the keys on a piano are called orchestra bells or glockenspiel. Larger ones with built-in vibrato are vibraphones.
If the bars are made of wood, it's a xylophone (literally "wood sound"). Xylophones can be marimbas.
But the ones Wire Weasel described would be "wind chimes".
I was waiting for Beetle to chime in on this. I knew he would have a rather resounding answer. :whistle:
Thanks for all the responses guys. Actually Mo nailed this one. When looking for what I'm referring to on the internet & ebay for purchase....they are called Bar Chimes.
TNX !!
It may be just a matter of semantics but hollow tubes, as you asked about, would be tubular chimes while solid bars as Mole mentioned would be bar chimes.
Tubular bells?
This is probably your speed.
YouTube - cookie tin guitar
  • @ heartbreaker3473:
