HR2600 RIT MOD
The RIT mod is simple for the HR2600 .
Open the top cover .First locate the orange wire on the 5 wire connector toward the left center of the main board (Violet/Brown/Orange/Yellow/Blue) . Clip the wire. I left enough to be able to reconnect if needed. Next solder the orange wire to the jumper 13 (JV77) +8V constant . The wire jumper # is not printed on the board. It is a horizontal wire about an inch long that is flat to the board . ( See pic below for locations )
Next, cut
D43. ( located in the front right side of the board toward right front corner section )
The next thing is to center the RIT. Turn the radio over and lift off the bottom cover being careful of the speaker wires.
Place the mode switch on AM and set the frequency to 28.000mhz. Place the RIT in the 12oclock position. Push the RIT button "in" .
Next connect your frequency counter to
TP304.
Adjust
L318 for 38.695Mhz .
With the RIT pushed "in" the Tx and Rx will track together .
Here are the adjustment points for frequency alignments from Roger's site-
Connect a Frequency counter to TP306. Adjust L315 for 6.200Mhz Connect a Frequency counter to TP304. Adjust L318 for 38.695Mhz
Connect a frequency counter to TP2.
Set the Mode switch to USB, adjust L10 for 10.6975Mhz.
Set the Mode switch to LSB, adjust L9 for 10.6925Mhz
Set the Mode switch to CW, adjust L8 for 10.6950Mhz
Adjustment locations above are shown below. The board below is the top of the main board.
Diagram can be found at -
http://vss.pl/mods/mods.php3-radio=uniden&model=hr2600&selectid=all.htm#2199
