I bet you have an impedence mismatch between the radio and the amp. What length of coax jumper are you using? Try a longer jumper and see if that helps. Sometimes that's the only way you can correct things without having the amp worked on.
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=moleculocdx363>MoleculoCDX363</A> at: 5/31/04 2:33 pm
