Ok.... I have an old 2 pill (as in 16 year old Train built) I was using as a 4 pill driver. I blew the pills around 12 years ago and never replaced them, I pulled the pills with intentions of replacing them but came across a awesome deal on a 2x4 so I just stuck it in the closet. Everything is still in the box except for the pills, which I can't for the life of me remember what they were. Is there any way to determine what they were (or what will work) by the value of the silver dips and the amount of transformer wraps?
Input is a 330 SD
Output is a 1000 SD
Both transformers are a 2/3 wraps.
The Collectors have a 120 SD going to ground.
Thanks for any help or leads you can give me.
**edit to add**
digging around looking at the TS250 schematics, the wraps and values appear to match 2290s very closely.
Input is a 330 SD
Output is a 1000 SD
**edit to add**
